Router restart
littlear
Router restart
Hello,
Is it possible for someone to restart my router remotely, so that it will pick up my new static IP address?
5 REPLIES 5
Mav
Fixes: 515
Re: Router restart
Moderator's Note(s)
Thread moved from ADSL Broadband to My Router.
Forum Moderator and Customer
Mav
Fixes: 515
Re: Router restart
You shouldn't need to get the router restarted remotely.
Assuming you have the Hub Zero (AKA 2704n) you can access your router's home page by entering 192.168.1.254 in your browsers address bar (you may need to enter your router's admin and password details which are on the back of the router. You can then select 'Disconnect' then 'Connect'.
If that hasn't done it you can restart the router by going to Advance Settings - System and click on Restart my Plusnet Hub.
littlear
Re: Router restart
Hi thank you for your reply.
My problem is that I'm currently not near the router and so I can't access it via it's local IP address. Are you able to PM me the current external IP?
Regards
Fixes: 419
Re: Router restart
Moderators are customers like you and I.
Can you get someone to switch the mains off and back on.  This will reboot the router and do the job,
Jubby
All Star
Fixes: 31
Re: Router restart
Hi @littlear,
Thank you for getting in touch.
I have performed a session kill on your connection, the connection has been stopped and restarted to assign the new IP. The IP address has also been provided to you via a ticket on your account which you can access here.
Thanks again.
 Lewis G
 Infrastructure Operations Professional
