Router redirections
scargill
Router redirections
I'm having immense difficulty with port redirection.  Having figured out the weird and wonderful way of doing this by defining "games" in the Plusnet Hub One (which I am only using as I suspect a connection issue with my TPLINK) I've set up a port redirection for port 1880 so that I can access a server externally. This is EXACTLY what I do with the TPLINK and other routers and that works perfectly.
Yet, once set up, on my mobile app I can set up the internal IP of the server and it works as before - but put the external address - and it does not.  Having defined the game and set up the port redirect, am I missing something? Obviously I have the actual subdomain name pointing at my Plusnet fixed IP address.
