Router recommendations, NAT problem.
Stringwalker
Hi, I apologize for another post, can anyone recommend a router that can be used or replace the hub one.
Also my NAT keeps changing, after I reset my router it shows moderate or type 2, which is what I want, but after a day or so it shows as open?
I found out yesterday my firewall had been turned off, I had it on strict, I have no idea how long it's been off, months or a year. I have no idea why it was turned off, never missed a payment etc, thanks.
1 REPLY 1
Fixes: 1,467
Re: Router recommendations, NAT problem.
Moderators Note
This topic has been moved from Fibre to My Router
