Router problem.
- My Router
- Router problem.
Router problem.
29-10-2016 2:38 AM
I've just had a replacement router and It's connection to my windows 7 computer has a problem. I have to type in the wi-fi pass word each time I switch on and also the WPS led is continually flashing.
Re: Router problem.
31-10-2016 4:31 AM
Which model Plusnet router are you using? Hub Zero or Hub One
Do you have same issue with other wireless devices?
Re: Router problem.
31-10-2016 3:01 PM
Hi @erikroberts,
I am sorry to hear about this and the issues that you are having.
Can you please perform a factory reset on your router please as this may help with your issue. To perform this please follow the instructions here from this link https://www.plus.net/help/broadband/router-user-guides/
If this fails with the connection of your router to your laptop then I would consider updating your software to a newer version of operating system.
Re: Router problem.
31-10-2016 3:33 PM
That has to be the most unhelpful suggestion I have read recently
Re: Router problem.
31-10-2016 3:51 PM
Re: Router problem.
31-10-2016 4:53 PM
totally agree ! a new version of windows will not cure a Router problem .
Do you have access to another router , to rule out that the replacement is not duff ?
Re: Router problem.
01-11-2016 7:30 PM
Hello everyone. I decided to switch the router off and leave it off over night. I then switched it on again the next day and Hey, it worked fine. No more flashing WPS and no longer having to type in password.
Re: Router problem.
02-11-2016 7:37 AM
Bet your happy you dont have to pay £70 - £80 on a new OS as suggested
