Router keeps restarting
- My Router
- Router keeps restarting
06-02-2019 9:39 PM
Recently my router which I've had for about a year has started to restart itself quite often. Does anyone know if this a firmware or hardware issue? Any help would be appreciated.
Re: Router keeps restarting
06-02-2019 9:58 PM
Sorry to hear this.
We're definitely seeing the drops you're experiencing:
Is your router actually rebooting itself (the light goes to green) or just dropping the connection (the light turns orange)? I'm asking because it looks like we're detecting a potential fault close or within your property:
Test Outcome | Fail: Problem Explanation: [ OD508 ] Issue identified at or near to the end user premises. Access may be required to resolve the problem. |
Test Outcome Code | GTC_FTTC_SERVICE_1625 |
Description | Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report |
Main Fault Location | CE |
Sync Status | In Sync |
Downstream Speed | 35.0 Mbps |
Upstream Speed | 10.0 Mbps |
Appointment Required | Y |
Fault Report Advised | Y |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 385.7 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Low |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-20M Downstream, Retransmission Low - 0.128M-10M Upstream, Retransmission High |
Time Stamp | 2019-01-24T22:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 11.6 Mbps | 39.9 Mbps | 27.1 Mbps |
Up Stream Line Rate | 0.8 Mbps | 10.0 Mbps | 9.7 Mbps |
Up Time | 465.0 Sec | 900.0 Sec | 889.8 Sec |
Retrains | 0.0 | 23.0 | 0.3 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-02-06T21:24:42Z | 2019-02-06T21:39:42Z |
Ingress Code Violation | 6 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 117 |
If the light on the router goes green it may be worth us replacing it for you, however if it just goes orange, then I'd recommend trying the steps Here first before we look at replacing the router. Failing all that I'd head on over Here to raise a fault.
Hope this helps.
07-02-2019 9:22 AM
Thanks for the reply. My hub just goes orange. Sometimes it does go back to being blue without me doing anything. Other times I do have to restart it.
I will try testing the master socket and see what happens from there.
07-02-2019 10:53 AM
16-02-2019 5:06 PM
I have taken the face plate off of my master socket and installed a micro filter. This did seem to cure the problem but yesterday my connection kept dropping out and the hub light went orange. Any help or idea on what I could do next?
17-02-2019 5:47 PM
Hi @sd01822, thank you for getting back to us and I'm sorry to hear the connection issue persists. After testing today there certainly still looks to be something out of place somewhere and upon raising a fault on the issue our suppliers have advised a engineer would be needed to come out and investigate further. In which case, I have updated your account with a fault ticket with information required from yourself so we can progress this fault further.
Your fault ticket can be seen here.
If you could please drop us a message on here after updating the ticket as we'll get this picked up for you as soon as possible.
