Router keeps failing
helpmeplease20
Over the last week my router has failed 3 times. Although I managed to get it working by following the re-connection instructions.  The light flashes orange, then when I restart it goes green then turns blue for a few seconds and then flashes orange again.  This can go on for 20 minutes before it starts working normally.  I'm currently working from home and it  failed this afternoon during a Microsoft team call with my colleagues.  I'm losing confidence in the service that Plusnet provides. I need to know if my router needs replacing, but I can't get through to customer services either on line or via the phone which is very frustrating.  I thought Talk Talk was bad, but at least I could get through to them.   You only find out how good your service provider is when there is a problem and I've found out the hard way!  If these posts are being monitored by Plusnet support, please help me!
1 REPLY 1
Mav
Fixes: 515
Re: Router keeps failing
Moderator's note(s):
Thread moved from Community Site Feedback to My Router.
Forum Moderator and Customer
