Router keeps disconnecting
- My Router
- Router keeps disconnecting
04-03-2021 8:37 PM - edited 04-03-2021 8:37 PM
(Hopefully this is the correct place to post this)
I've been having trouble with my router for the past 2 days, it started on the 2nd of march, it was fine on the 3rd, and now its doing the same thing today (4th) it will keep disconnecting every 10-20 minutes. the light will change from blue to orange and an orange B will appear (not flashing) it eventually comes back on but will do the same thing over and over.
Re: Router keeps disconnecting
05-03-2021 9:22 AM
Thanks for your post @Zach2123
I'm sorry to hear that you're having connection issues.
I've been unable to find your account via the usual methods.
Can you drop me a PM with your account username?
