Router has loud high pitched pulsing noise
- My Router
- Re: Router has loud high pitched pulsing noise
17-08-2017 11:32 PM
18-08-2017 8:25 AM
Is it coming from the power adapter or the router itself?
18-08-2017 10:13 AM
The Hub One is known for making an electrical noise whilst 5G is in use but not as loud as you describe. Sounds like a fault with either the router or power adaptor. I'd see if Plusnet will replace it for you.
18-08-2017 11:43 AM
18-08-2017 7:47 PM - edited 18-08-2017 7:50 PM
- My Router
