Router faulty
- My Router
- Re: Router faulty
Router faulty
17-08-2019 12:44 AM
Re: Router faulty
17-08-2019 3:53 AM
Thread moved from Tech Help to My Router.
Forum Moderator and Customer
Re: Router faulty
17-08-2019 9:26 AM - edited 17-08-2019 9:30 AM
@mitrecyclers Welcome to the forum.
If you have a Hub One then it's probably the latest firmware that's causing the drops. Some Hub Ones hiss especially on the 5GHz band. Plusnet consider this to be acceptable and will only advise you switch off this band.
You can get another Hub One for the P&P charge if you take out a new contract.
If you want a better router that does not drop connections or hiss go onto EBay and get a BT Smarthub 6. They go for around £20 or less. Setting instructions will be found here https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
If you buy a Hub One from Plusnet they charge around £100 and it probably won't be any different.
Re: Router faulty
17-08-2019 9:38 AM
Re: Router faulty
17-08-2019 11:17 AM
What do you mean by better? More expensive, more options such as QoS control, monitoring functions, capability to set own DNS server etc.? You just need to list what you want from a router then look at available devices. You will probably get nearly as many different recommendations as people who respond. This is a good place to start. https://forum.kitz.co.uk/index.php/topic,14436.0.html
My recommendation is a cheap and better alternative to Plusnet hubs that covers the same functions only does it better. If you want more bells and whistles then that's a different matter.
Re: Router faulty
17-08-2019 4:47 PM
Re: Router faulty
18-08-2019 7:38 AM
If you buy a second hand BT Smarthub 6 and decide you want something better you can always sell it again and you won't have lost much.
In therms of "improvement per pound" the BT Smarthub is probably the best you will get.
TP Link make some routers that are well thought of at around the £100 mark.
Otherwise something decent from Draytek with business style features will be more than £200.
There is no single step up from the Plusnet supplied unit which suits all.
Re: Router faulty
18-08-2019 11:54 AM - edited 18-08-2019 11:57 AM
@mitrecyclers wrote:
Better mean better speed / range and reliability. I will check that forum page as well. Thanks.
If you have read Smarthub 6 reviews suggesting reliability issues then also look at the review date. In the early days there were firmware issues, long since resolved. Despite being used with Plusnet these hubs still get automatic firmware updates from BT. Also consider that there are possibly millions of these in service.
