Router dropping internet access via wireless only
mgh65
My Plusnet Hub one Router loses wireless internet access seemly approx every 10 minutes and may return sometime within the next hour.
I see this post reported a similar problem but with 494 replies I am not sure what the solution ( if any ) was.
Hub One losing internet connection on 5Ghz WiFi on... - Page 2 - Plusnet Community
Broadband stays connected, its fine on LAN
The wireless connection reports no internet access at the same time on a desktop PC, 2 laptops and my phone.
I've done all the restarts and un-plugs but no difference. We do have a wireless extender but i have turned that off to simplify the problem.
There is no distance/signal strength problem ( same room for all devices ) . We've tried the device one at a time and its the same for all of them ,and no one device is causing the issue because we turned them off while testing the other devices
I dont know when this started, we only use wireless occasionally up to now but a new laptop has revealed the issue. I suspect its been around a while but getting worse ( my phone kept dropping onto 4G but as I dont use it i thought nothing of if )
13 REPLIES 13
Legend
Fixes: 254
Re: Router dropping internet access via wireless only
Welcome to the forums, @mgh65 One question - what version of firmware is it running?
mgh65
Hi John,
It is 4.7.5.1.83.8.263
I tried turning off 5Ghz as per this post, but that has no change
Hub One - 5GHz WiFi issue - Plusnet Community
Legend
Fixes: 254
In that case, although it is being rolled out to all users currently, you could ask for an out-of-sequence upgrade to the latest FW which should resolve it. Post a request in here:https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/m-p/1818625#M27223
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to My Router
mgh65
Thanks, I've done that.
I see every post related to this issue seems to have thousands of replies so clearly its something plusnet have not managed well
Legend
Fixes: 254
@mgh65 I'm no longer a  PN customer, so not a 'fan-boy', but that is a slightly unfair comment - they have been working on it for some time, but the resolution has proved elusive until recently.
mgh65
fair enough, its the comms that upsets, not the technical solution
my comment comes on the back on nonsense from cust support about restart this, unplug that, unplug everything!, whats your PC o/s, we'll call you back, we'll check your BB ( ITS WORKS FINE ON LAN but you still want to check it...."yes" ) ....when really, they have a known problem.
Had they just said "Oh yeah, we know we have a problem with that, register your interest in a solution on post xyz and we'll inform you when its ready"
But they didnt, i had days of call centre denial.
Thank you for your help John, it was so quick to point me somewhere useful, whereas plusnet were not capable of doing that
Legend
Fixes: 254
Understand your point, but unfortunately front-line call handlers are not technically trained - they follow standard procedures which many companies are slow to update/modify
TheMightyAJ
Fixes: 126
Hi @mgh65,
I'm sorry to hear about your experience and I apologise for the delayed to this thread. I hope that the advice given in this thread helps, however if there are any further issues, please don't hesitate to get back in touch and we'll be happy to assist wherever we can.
 Alex H
mgh65
Hi
i dont really understand this statement, do you think the issue is resolved ?
"please don't hesitate to get back in touch and we'll be happy to assist wherever we can."
Pleas consider this me not hesitating to get back in touch as I'd like plusnet to assist wherever they can....to resolve the issue please.
Legend
Fixes: 254
@mgh65 Now you have asked for the updated firmware in the other thread, it will be actioned as soon as the Product Specialist picks the request up, but he is not always available. Rest assured you will get a reply from him on that thread when the update has been pushed through.
TheMightyAJ
Fixes: 126
Hi @mgh65,
Apologies for the misunderstanding. I'd posted the above as I can see you've posted in the thread suggested by @jab1 yesterday. I'm afraid that I have no influence over the requests logged in that thread, though please rest assured that the request will be picked up sooner or later, as have all the other requests in the thread before it. Once the request has been actioned I sincerely hope that the problems you've reported are resolved, however if they are not please let us know and we'll be happy to investigate the matter further from there.
 Alex H
mgh65
Arh, thank you, sorry for being such a grumpy man, taking out things that are external to this on plusnet is unfair of me
