Router disconnected
- My Router
- Re: Router disconnected
Router disconnected
03-12-2020 11:24 AM
Internet light is red, i reset it and its connected then still doesnt work. Shortly after the light goes red again. Click connect and nothing happens. This is the second time since i moved in a month ago.
Message 1 of 2
(343 Views)
1 REPLY 1
04-12-2020 3:34 AM - edited 04-12-2020 3:41 AM
You may have a fault on the line, or the hub could be faulty.
If your property doesn't have a modern filtered socket which has separate two sockets, one for phone, other for broadband, have you tried the test socket?
You should phone Plusnet and report the problem imho.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
Message 2 of 2
(298 Views)
