Router crashing and rebooting after port fowarding attempt.
- My Router
- Router crashing and rebooting after port fowarding...
14-05-2017 4:20 PM
I have tried to port forward the following ports on my router:
UDP: 47998, 48000, 47999, 48010
But after trying to apply these settings my router crashes and reboots. Also, if I try to access the port forwarding section of my router it then crashes again and reboots. The only way I can get back into the port forwarding section of my router is to reset it.
Image Attached.
Image Attached.
Message 1 of 3
(598 Views)
2 REPLIES 2
Re: Router crashing and rebooting after port fowarding attempt.
15-05-2017 11:56 AM
Have you followed the steps here: https://community.plus.net/t5/Gaming/Plusnet-Routers-and-Port-Forwarding/m-p/1307974#M17457
From the screenshot attached it does seem like it but thought it was worth double checking.
Message 2 of 3
(547 Views)
15-05-2017 3:13 PM
Yes, I have followed those steps. That was same page i went through to set the port forwarding as i was unsure about which numbers to put in the translate to columns.
Message 3 of 3
(532 Views)
- My Router
