Router change
- My Router
- Router change
Router change
19-04-2020 7:34 PM
Upgrading from Adsl2 to fibre on Tuesday ..... Is it worth plugging the hub one in early or wait until im switched over ?
Router just pick up the fibre change over ?
Any advice would be greatly appreciated
Message 1 of 2
(416 Views)
1 REPLY 1
Re: Router change
20-04-2020 6:20 AM
You can plug the hub one in. It will drop the connection once the engineer has done his work in the local cabinet.
The hub one works with both ADSL and VDSL.
Message 2 of 2
(368 Views)
