Router causing beep
- My Router
- Router causing beep
Router causing beep
25-03-2017 2:37 AM
Why when my Plusnet Router is switched on do I get an intermittent beep beep in my speakers? It is quite annoying and means I either have to turn off the router or speakers!
Message 1 of 3
(598 Views)
2 REPLIES 2
Re: Router causing beep
25-03-2017 9:51 AM
Make sure the router and speakers aren't right next to each other. Could be interference
Message 2 of 3
(560 Views)
25-03-2017 6:31 PM
Thank you,
there is about two foot between them but it is strange because if the computer is off but the speakers are on (they are amplified) and the router is on, I still get a beep. It is not all of the time though. it just starts up now and then.
Message 3 of 3
(530 Views)
