Router and Citrix
- My Router
- Router and Citrix
Router and Citrix
10-04-2016 9:08 AM
Good morning all
I'm using my work laptop via Citrix and have the following problem:
Logging into Citrix isn't a problem however when I try to open Microsoft Outlook I get the following message "could not open Outlook. The information store could not be found". I also cannot gain access to Microsoft Lync, the Internet or works intranet. The only thing I can get access to are my files stored on my works server.
I have contacted my works IT department and they are not sure what the issue is as I am clearly connecting to their server. They keep repeating "its Plusnet, we always have problems with them, just reboot both your router and laptop and re-try". Not helpful at all as I have done this several times now with no luck.
can anyone help please?
Re: Router and Citrix
10-04-2016 10:22 AM
10-04-2016 10:32 AM
No they are not.
I was working away fine on Thursday, logged back in Friday to these error messages. I took my laptop into work yesterday to synchronise to the network just in case that had something to do with it (more like wishful thinking) but no joy.
11-04-2016 11:03 AM
It'll not be what I thought it was then. Not unless the problem started around mid-March. With this issue excepted, there's nothing (Plusnet) network-side that should be causing you any problems
