Router advice for an idiot
lol999
Okay, so when fibre broadband came in the engineer fitted a white BT box and gave us a simple Plusnet router to plug into it.
I soon swapped that out for an Asus router which has been great but now I want to change to a combined unit and use the Asus as a wifi extender on my daughters nertwork as the Plusnet provided router there is woeful on wifi.
Thing is I'm getting confused. Do I need something with a modem built in? Is it just a router. If so does that have to be VDSL?
Any advice and recommendations would be much appreciated.
Thanks!
6 REPLIES 6
RichardB
Seasoned Champion
Fixes: 39
Re: Router advice for an idiot
Hi @lol999
Re>> Do I need something with a modem built in? Is it just a router. If so does that have to be VDSL?
The simple answer is Yes and Yes.
If you are thinking of sticking with ASUS, whatever you do do you buy an ASUS DSL-86U.
The DSL-86U has a terrible Mediatek modem device.
The ASUS DSL-88U is reported to be OK as it uses an Broadcom modem device.
Regards
Richard
Mustrum
Fixes: 77
@RichardB  I think you missed a "don't" as in don't buy that Asus model.
RichardB
Seasoned Champion
Fixes: 39
Yes a bad typo on my part.
Do not buy an ASUS DSL-68U
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to My Router
lol999
No i won't be buying either of those as I can't afford them. Ideally I'd like to keep it below £70!
Mustrum
Fixes: 77
If you have recently or about to update your PN contract, you could do worse than ask for a new router, at worst £6.99 postage. Just make sure you get it updated to the latest firmware.
If not, then many people get hold of a BT HH6 and just insert the PN username and password - eBay/Free ads and so on usually have some available cheaply.
Much will depend on what you want from the router?
