Router WiFi Problems
- My Router
- Router WiFi Problems
Re: Router WiFi Problems
30-03-2019 5:45 PM
Absolutely...my router hasn’t had any settings modified, so going to default on a previous firmware is fine.
30-03-2019 5:48 PM
Thanks for the confirmation, @Christian1979.
I'll add this to the report that's compiled at the end of each day, and request that we get this done for you once the products team are back in on Monday, we can then proceed accordingly from there.
Kind Regards,
MoR
(tagging @bobpullen so he has visibility of the thread)
06-04-2019 3:01 PM
Just to update this thread...
I split/unsynched the frequencies and now have separate 2.4Ghz and 5Ghz wireless networks. All my permanently connected home stuff is on the 2.4Ghz and the laptop/iphone/ipad on the 5Ghz. Everything stable now and for the last week, the 5Ghz network hasn't dropped. So, its got something to do with synching the frequencies into one network?
06-04-2019 5:52 PM
Well, this tends to be common issue with BT and Plusnet routers. Why the default is to merge them from factory is, imho, 'stoopid'.
It would save all this hassle if they were split, right from the get-go
What happens is 5GHz device bounce from 5GHz to 2.4GHz most of the time. More so if you're just on the limit of the 5GHz.
(5GHz is better close to the router, but 2.4GHz reaches further)
(5GHz connects faster to the router, not necessarily to the www)
HTH
06-04-2019 7:03 PM
This topic has been moved from Fibre Broadband to My Router.
06-04-2019 7:12 PM
There are arguably pro's and con's to both approaches. Yes, in this instance splitting the frequencies helps, but we're seemingly looking at a problem that shouldn't exist in the first place?
By splitting the SSIDs out of the box, you're adding complexity that some of our non-technically inclined customers may not have any desire to understand e.g. if you choose to connect solely to the 2.4GHz radio without understanding the implications, then you could be limiting the potential of your connection and introducing unnecessary congestion from competing access points.
Not entirely relevant to the Hub One, but you'll see the merged approach more and more as mesh Wi-Fi becomes more prevalent and Wi-Fi technologies mature (most mesh solutions require the 2.4GHz and 5GHz SSIDs to be aligned).
I was hoping to 'do the rounds' and dig a bit deeper into some of these complaints this weekend, however it's unfortunately going to have to wait as I'm without my laptop PSU and I've no other mechanism of getting onto the corporate VPN at the moment
Hopefully make some progress next week...
06-04-2019 8:33 PM
I guess one could argue it's more pro's. It would appear that (my guesstimate) 95%+ are advised to split and voila it's fixed.
Totally agree. Though if the routers were split at the 'factory', with yous lot, busy ironing this out, for the update to then merge them back, could avoid this sort of issue in the first place. This was an issue on the HH5, so plenty of time (you'd have thought) to suss it out...?
Get that too Bob:). Though my thoughts above might be a better approach, perhaps? Let's say, for ease of use, WPS oly connected to 2.4GHz only, then users make a choice to manually connect to either?
From my own experience, thus far, 2.4GHz is the better option, as 5GHz at roughly 6 metres is problematic. Understand the limits this causes, but can't see the majority of users sitting near the hub for most of the time. IDK, just guessing.
And I can see the positives to this too, but for me, the cost implications would be my limiting factor. If you're planning on releasing one, stick my name on a trialists list!!;)
There's no rush. BT had long enough and I'm grateful you'll be seeing this one through to a positive conclusion won't you?
If you need a 'victim' for testing, although I'm about done (can see you posted over there, but not read it yet) with my testing, give me a shout. I'd love to finally crack the HH5/H1 issue, once and for all.
Just very frustrating.
07-04-2019 3:39 PM
07-04-2019 4:01 PM
07-04-2019 4:32 PM
Hi @Bones1959,
I'm sorry that you've been experiencing problems with the performance of your connection and for the inconvenience that this has caused. I can see that the last advisor that you spoke to treated this as a wireless issue, despite you mentioning that this is also affecting wired connections. I'm sorry for this oversight and I'll pass feedback on.
Testing your line isn't picking up the problem from here and indicates that your line is currently syncing at 36.3mbps:
If you've not done so recently, please can you run through our troubleshooting guides here. If these checks don't resolve the problem, please report it here and let us know when you've completed it.
07-04-2019 8:19 PM
07-04-2019 9:19 PM
Hi @Bones1959,
Thanks for getting back to us.
I appreciate your comments that you have been through our technical procedures before. We will be happy to look into any issues further, do come back to us if you feel the need to do so.
With regards to our routers, as with any hardware there can be issues that are experienced from time to time however there is no widespread issue with the routers that is a cause for concern. We will always first look into what could be causing connection or speed issues as and when they occur, if a router does not appear to be working as it should then we will look at replacing the router if the situation demands it.
If you need any further assistance, please let us know.
Thanks - LF
08-04-2019 2:11 PM
08-04-2019 2:47 PM
Thanks for the kind comments, @Bones1959.
I won't tell you what my username refers to but I'm sure the answer is out there somewhere.
Anyhow, do let us know how the 'channel hopping' goes. I hope you find your optimum before you get to 13.
Thanks - LF
25-04-2019 6:53 PM
Checked broadband speed yesterday 15.5mps, was watching skyGo app was pixelation was terrible! Worse than when we was getting 14mps max with another provider. Seems to drop off when big sporting event is on , tried all 13/14 channels, no great change, just a major pain in ???? Changing channels every night. If you say I’m receiving 36mps but by the time it reaches 3 different laptops, all windows 10 all using 1 Ethernet cable and without cable 2 foot from router to me proves the routers not working right.
