Router Wi-Fi Problems Solved
Christian1979
Just updating this thread that got a bit hijacked...
https://community.plus.net/t5/My-Router/Router-WiFi-Problems/td-p/1626208/
In summary, I had huge problems with my Plusnet router. The wi-fi would constantly fail (twice a day on average) when in sync’ed mode and I’d have to reset the router to get Wi-fi back. Anyway, I solved it which might help anybody with the same problem. I purchased BT Whole Home Wi-fi and disabled the rubbish Wi-fi on the Plusnet router. Problem solved...I now have totally stable Wi-fi throughout my home with a good signal everywhere. Yes, it’s cost me an extra £99.99 but its definitely worth it.
2 REPLIES 2
Fixes: 401
Re: Router Wi-Fi Problems Solved
That’s one solution. Another and cheaper option is to dump the Plusnet router altogether and fit a BT Smarthub 6 bought off EBay for about £20.
Christian1979
True. Either way, solution is to ditch the Plusnet router.
