Router Suggestions For Unlimited Fibre
- My Router
- Router Suggestions For Unlimited Fibre
06-12-2020 12:17 PM
I'm upgrading to Unlimited Fibre.
I heard the Hub One that Plusnet supplies is not that good.
Should I just get one free and pay the £6 postage fee or another make/model?
Thanks in advance?
Re: Router Suggestions For Unlimited Fibre
06-12-2020 12:32 PM
The advantage of having a hub one is that you can plug it in if you have any line problems, which might help Plusnet with testing the line.
Personally I would put the money towards the approx £20 that the better BT Smarthub 6 costs from an auction site such as Ebay. Settings are here. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
06-12-2020 1:05 PM
Great thanks for the reply.
Much appreciated
06-12-2020 1:16 PM
You might try Gumtree as well, maybe just my location but I found my HH6 only six miles away and using Baldrick's guide had it running perfectly in about an hour from first seeing the ad.
06-12-2020 1:18 PM
I'll try that.
Much appreciated
- My Router
