Router Suggestions For Unlimited Fibre
cybertez
I'm upgrading to Unlimited Fibre.
I heard the Hub One that Plusnet supplies is not that good.
Should I just get one free and pay the £6 postage fee or another make/model?
Thanks in advance?
4 REPLIES 4
Fixes: 419
Re: Router Suggestions For Unlimited Fibre
@cybertez
The advantage of having a hub one is that you can plug it in if you have any line problems, which might help Plusnet with testing the line.
Personally I would put the money towards the approx £20 that the better BT Smarthub 6 costs from an auction site such as Ebay. Settings are here. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
cybertez
Great thanks for the reply.
Much appreciated
Longliner
Seasoned Pro
Fixes: 7
You might try Gumtree as well, maybe just my location but I found my HH6 only six miles away and using Baldrick's guide had it running perfectly in about an hour from first seeing the ad.
cybertez
OK cheers,
I'll try that.
Much appreciated
