Router Settings
- My Router
- Router Settings
Router Settings
22-07-2016 6:51 PM - edited 22-07-2016 6:52 PM
Hi everyone, just writing to ask for some advice and help.
So I typed my internet IP (I think that's what it is?) to try and restart my router on the internet rather then turning it off by plug. I was unable to login on my iPhone 6 nor my iPad mini, but I was able to login on my laptop.
I don't know whether Plusnet have done some changes to the services which may have caused this to happen, but if I need to change the wireless channel in the future, it's going to have to be done on my laptop rather then my IOS device which is a bit of a hassle. Any advice would be much appreciated.
I have done a factory restart (the little button on the back of the router) and it made no difference.
Thanks!
Thanks!
Labels:
Message 1 of 3
(753 Views)
2 REPLIES 2
Re: Router Settings
23-07-2016 6:54 AM
Which Plusnet router model are you using?
Have you considered the issue may be with due to a recent update to the Safari web browser on your IOS device?
Can I suggest you try an alternative web browser on your IOS device? eg. chrome, if available.
Message 2 of 3
(725 Views)
Re: Router Settings
23-07-2016 9:20 AM - edited 23-07-2016 9:54 AM
Hi Bill,
Thank you for the suggestion of using a different browser. I'm using the Plusnet Zero Router. Ufortunately, using Chrome did not work ether. I have noticed since the latest IOS update this issue has happened.
Thanks again for the help!
Message 3 of 3
(712 Views)
