Router Replacement
jpgreen44
Router Replacement
Hi there, I think the router we have at our scout hq has seen better days and needs replacing. The question is what WiFi router do I replace it with? We need one with a good WiFi range to reach the back of the building and preferably very easy to set up. Do I need to find out if we have a fibre account or not before I start to look at different routers?
2 REPLIES 2
bill888
Champion
Fixes: 38
Re: Router Replacement
Yes, you will have to know if you are currently connected to fibre services if you plan to purchase a 3rd party modem router.  If you google the make and model number of your current modem router, that may also answer your question.
If a wifi router can't provide acceptable coverage/speed due to the large size and type of construction of the premises, you may have to consider installing ethernet cable, to provide a wireless access point at the rear of the property.  You may be able to use powerline technology instead of running cables. You could also use wireless repeater/extenders.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
Fixes: 49
FTTC uses VDSL technology as opposed to the older ADSL.
Most (if not all) VDSL routers can work with ADSL but ADSL routers don't work with VDSL unless you have a separate (old school) OpenReach modem.
If the Scouts are still on ADSL it might be worth upgrading to FTTC (If it's available) both for the better speed and you'd get a new router as part of the package. Check what's available by putting the telephone number in
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Does the WiFi on the current router work OK for the premises. If so, posting the make and model would help identify a replacement.
