Router Rebooting - "Boot reason: watchdog reset (cause: 0x3)"
- My Router
- Router Rebooting - "Boot reason: watchdog reset (c...
24-06-2020 4:04 PM
Hi, seems I'm another with these bothersome Watchdog Resets every few days (sometimes more often).
I've been having problems with the 5GHz wifi drop-outs since getting the router in September (raised in a different thread) so switched my laptop to a cabled-connection (through a TPLink PowerLine device) for a more reliable connection - but was still getting intermittent loss of connection every couple of days.
Checking the router logs, each time it happened, I saw this....
15:17:21, 21 Jun. | ( 31.260000) System up, firmware version: 4.7.5.1.83.8.263 |
15:17:07, 21 Jun. | ( 17.710000) System start |
15:17:07, 21 Jun. | ( 17.710000) Boot reason: watchdog reset (cause: 0x3) |
23:05:56, 15 Jun. | ( 31.200000) System up, firmware version: 4.7.5.1.83.8.263 |
23:05:42, 15 Jun. | ( 17.870000) System start |
23:05:42, 15 Jun. | ( 17.870000) Boot reason: watchdog reset (cause: 0x3) |
04:07:52, 10 Jun. | ( 31.180000) System up, firmware version: 4.7.5.1.83.8.263 |
04:07:38, 10 Jun. | ( 17.880000) System start |
04:07:38, 10 Jun. | ( 17.880000) Boot reason: watchdog reset (cause: 0x3) |
19:51:34, 09 Jun. | ( 31.510000) System up, firmware version: 4.7.5.1.83.8.263 |
19:51:20, 09 Jun. | ( 18.140000) System start |
19:51:20, 09 Jun. | ( 18.140000) Boot reason: watchdog reset (cause: 0x3) |
21:49:11, 07 Jun. | ( 33.100000) System up, firmware version: 4.7.5.1.83.8.263 |
21:48:56, 07 Jun. | ( 18.030000) System start |
21:48:56, 07 Jun. | ( 18.030000) Boot reason: watchdog reset (cause: 0x3) |
11:41:31, 02 Jun. | ( 33.530000) System up, firmware version: 4.7.5.1.83.8.263 |
11:41:15, 02 Jun. | ( 17.510000) System start |
11:41:15, 02 Jun. | ( 17.510000) Boot reason: watchdog reset (cause: 0x3) |
08:59:17, 02 Jun. | ( 33.790000) System up, firmware version: 4.7.5.1.83.8.263 |
08:59:01, 02 Jun. | ( 18.090000) System start |
08:59:01, 02 Jun. | ( 18.090000) Boot reason: watchdog reset (cause: 0x3) |
09:48:28, 01 Jun. | ( 32.950000) System up, firmware version: 4.7.5.1.83.8.263 |
09:48:13, 01 Jun. | ( 17.830000) System start |
09:48:13, 01 Jun. | ( 17.830000) Boot reason: watchdog reset (cause: 0x3) |
Looking back through the logs, it looks like it's been happening pretty much since I got the router (it appeared to run a firmware update shortly after I switched it on for the first time):
00:00:33, 08 Nov. | ( 33.500000) System up, firmware version: 4.7.5.1.83.8.263 |
00:00:17, 08 Nov. | ( 18.010000) System start |
00:00:17, 08 Nov. | ( 18.010000) Boot reason: watchdog reset (cause: 0x3) |
22:29:34, 13 Nov. | ( 32.750000) System up, firmware version: 4.7.5.1.83.8.263 |
22:29:19, 13 Nov. | ( 17.760000) System start |
22:29:19, 13 Nov. | ( 17.760000) Boot reason: watchdog reset (cause: 0x3) |
07:34:06, 14 Sep. | ( 33.650000) System up, firmware version: 4.7.5.1.83.8.263 |
07:33:50, 14 Sep. | ( 17.750000) System start |
07:33:50, 14 Sep. | ( 17.750000) Boot reason: watchdog reset (cause: 0x3) |
23:04:57, 04 Sep. | ( 33.790000) System up, firmware version: 4.7.5.1.83.8.263 |
23:04:42, 04 Sep. | ( 18.730000) System start TR069 |
20:11:02, 03 Sep. | ( 32.970000) System up, firmware version: 4.7.5.1.83.8.259 |
20:10:47, 03 Sep. | ( 17.880000) System start |
Hope you can help!
Re: Router Rebooting - "Boot reason: watchdog reset (cause: 0x3)"
24-06-2020 9:14 PM
Sorry to jump on this message, but I'm having exactly the same issue... 'watchdog reset (cause: 0x3)', every day or so.
I see other similar problems that were seemingly fixed by the provision of a new router: https://community.plus.net/t5/My-Router/One-Hub-Watchdog-Resets-cause-0x3/td-p/1613381.
Plusnet: If the fix is indeed a replacement router, please may I have one?
Thanks.
- My Router
