Router Noise!
- My Router
- Router Noise!
Router Noise!
27-07-2020 9:19 AM
Re: Router Noise!
27-07-2020 9:39 AM
What model of router do you have and do you know approximately how old it is?
Sounds like it could be faulty, and I have read about these problems before on these forums.
PlusNet may send you out a replacement router and a returns bag for the old one.
This is for them to decide though, so hopefully a member of staff will pick this up.
Re: Router Noise!
27-07-2020 9:45 AM
Re: Router Noise!
27-07-2020 9:47 AM
@tj_bennett12 Welcome to the forum.
If you have a Hub One then Plusnet will tell you that this is a 'feature', is 'within limits' and it will improve if you switch off the 5GHz wireless band.
If it"s annoying you then go onto an auction site such as Ebay and pay little money for a BT Smarthub 6. Apart from having better and more stable WiFi performance they are silent. You will find setting instructions pinned at the top of this router board.
Re: Router Noise!
27-07-2020 9:55 AM - edited 27-07-2020 9:55 AM
Fair enough @Baldrick1
That what my sister uses, and the Hub One is in the front room where her and my niece often watch the TV.
If ours buzzed I would definitely getting complaints and I would know about it!
Re: Router Noise!
27-07-2020 10:04 AM - edited 27-07-2020 10:08 AM
I believe that it is caused by capacitors which can make a noise when passing ac signals. it depends on their type and casing, some types/makes can go noisy at any rime in their lifetime, or never. It can also vary between one manufacturer/batch and another.
In a previous life I was involved in the development of high power inverters and we had to wear ear defenders due to the noise that these and wound components made.
Re: Router Noise!
27-07-2020 11:24 AM
My dad used to be a TV engineer fixing the broken ones back in the day when TV's were really expensive and you didn't just chuck them if they go wrong like you do now.
I remember when a much younger me had to travel on a 20 min bus journey and back to ask for a specific chip. Managed to do that fine. Was a bit nervous as I didn't have a clue what I was doing. Story of my life.
I should have taken more of an interest than what I did.
So the house was full of TV's, my dad was repairing.
Anyone remember valves? I remember we used an older TV and it took 10 minutes for them to warm up.
I remember touching the outside of a tube and got an unpleasant electric shock.
"Those were the days of our lives" as Queen once said. 😁
Re: Router Noise!
27-07-2020 6:21 PM
