Router Keeps losing credentials
- My Router
- Re: Router Keeps losing credentials
13-08-2020 9:06 PM
I've managed to find my issue in this post from 2019. https://community.plus.net/t5/My-Router/Anyone-having-their-router-forget-their-password/td-p/165167...
I'm getting the exact same issue. I just need someone from plusnet to sort the issue. @Gandalf you managed to do this in the previous post.
If you can confirm that the account is properly activated at your side it would be helpful for one of your agents to call me to discuss further.
Message 1 of 4
(644 Views)
3 REPLIES 3
14-08-2020 9:44 PM
Hi plusnet
Anyone there give a flying? Would be nice to get some sort of response.
Ta
Ta
Message 2 of 4
(594 Views)
16-08-2020 10:51 AM
@BenDyson your account is fine. Your router is not correctly registered on the hardware management platform though. I've corrected that for you, so things should be sorted moving forwards. Shout up if not.
Message 3 of 4
(556 Views)
16-08-2020 1:48 PM
Thanks for that. I'll keep an eye on it and confirm.
Message 4 of 4
(537 Views)
- My Router
