Router Keeps Flashing orange - please help
- My Router
- Router Keeps Flashing orange - please help
20-08-2025 8:33 PM
Hello
My Full Fibre Router (Hub 2 I think it’s called) keeps flashing orange. I’ve tried numerous resets, turning off and on, disconnecting and reconnecting Ethernet cables and nothing whatsoever
I texted Help and the automate said they have detected the line but isn’t connecting to the router. I texted advisor for a call and ironically, Plusnet had a an issue and couldn’t connect to an advisor.
I’m losing my patience and need internet access for work etc.
I appreciate any help that can given
Message 1 of 4
(803 Views)
3 REPLIES 3
Re: Router Keeps Flashing orange - please help
20-08-2025 8:37 PM
@Fincha67 If you are on Full Fibre, what are the lights on your Optical Network Termination box doing when this happens?
20-08-2025 8:40 PM
If you're on Full fibre, have got the. router WAN port connected correctly to the ONT ?
20-08-2025 9:13 PM
Thanks for your reply. I figured it out. Somehow the ONT was unplugged. Thanks for your help
- My Router
