Router IP addresses, router changing them
t1m149
Why would my router be changing ip address,s ?
This stops devices connecting to the internet.
For example my Ethernet connected desktop PC had its IP changed from 192.168.1.xxx to 192.168.8.xxx
similar thing happened to my sons laptop and WiFi connected Amazon Echo
7 REPLIES 7
bill888
Aspiring Champion
Fixes: 32
Re: Router IP addresses, router changing them
What router do you have?
Are  you sure you haven't got a second router (perhaps misconfigured as a wireless access point) dishing out 192.168.8.x addresses to your devices (wifi by any chance) wired to your network while your main router (plusnet hub) is offering 192.168.1.x addresses?
Fixes: 200
@t1m149
Is your Ethernet connected device connected through a powerline device? it's not unknown for these if left with their default password to connect to a neighbours powerline network.  Also are you trying to connect your wireless devices to a different router or wireless extender?
VileReynard
Fixes: 20
Do you have more than one device handing out DHCP addresses?
What do these new-fangled Amazon echo things do?
Fixes: 200
My echo thing is quite dumb and has to pick up a DHCP IP address from a router using an app. There's no built in server.
That's why I can't get my head around a dumb wireless device magically changing it's IP address and ask whether the OP is accidently trying to connect to a neighbours network, which might well be showing a stronger signal, unless there's a echo varient with its own built in server.
VileReynard
Fixes: 20
When your desktop gets connected as 192.168.8.xxx, you ought to be able to find out what your local network setup looks like.
You could always run a port scan with your desktop, when you find the WAN address you could lookup which ISP owns that ip address. A free wifi app on a mobile can be used to track strongest wifi signals from place to place.
Fixes: 1,230
Moderators Note
This topic has been moved from Fibre to My Router
t1m149
Turns out a Wifi Ap had the same IP address as the plus net router.
I assume this was generating the different IP addresses.
How this was effecting the Ethernet connected devices is beyond me !!
