Router Firmware not updating
- My Router
- Router Firmware not updating
17-11-2018 8:31 PM
I've had my router about a year now and still showing last update unknown with a version number ending in .237.2.2.
Please can you push an update to my router at your earliest convenience? Alternatively, let me know if there is something I can do at my end to force an update.
Thanks in advance.
Re: Router Firmware not updating
19-11-2018 11:52 AM
Hi @Mabozza
Thanks for getting in touch regarding your router firmware.
The firmware version you have advised that is on your router is our current up to date - 4.7.5.1.83.8.237.2.2.
Are you experiencing any issues in particular?
19-11-2018 12:36 PM
Hi, Warwick and thanks for the reply.
No issues experienced, only wondering as there had been no updates in a year which seemed like their might be an updating issue.
I appreciate the quick response.
Thanks.
19-11-2018 5:40 PM
- My Router
