Router 2 Set Up
nigelbrand05
Router 2 Set Up
Good evening
Just been setting up a new router 2.  I am assuming that you are unbale le to separate the SSID bands in the setting, is this true?  If so what can I do when a smart lamp will only connect to a certain band?  When trying to connect the bulb I get a message informing me that it is not possible to connect.  It is OK with the router 1 and separate bands.
2 REPLIES 2
Fixes: 118
Re: Router 2 Set Up
@nigelbrand05
Login to the router management page and disable one of the WiFi bands. Then try connecting your lamp. If successful go back into the router and re-enable the WiFi band.
nigelbrand05
Re: Router 2 Set Up
Hi Brian
never thought of this.  I will give it a go.  Strange that only 1 device could not connect.
thanks
Nigel
