Request to upgrade router
- My Router
- Request to upgrade router
17-08-2017 2:24 AM
I was wondering if it would be possible to request a 'Hub One'? Assuming this is the latest offering.
I have always stuck with ISP supplied routers/modems, however I am finding this one to be somewhat restrictive. It also provides next to no diagnostic information, presumably due to being locked out of the modem.
The inability to see line stats makes it difficult to diagnose issues. A recent, rather frustrating example, I have recently been experiencing rubber-banding. Resetting the router has not fixed this (which I am loathe to do anyway because of DLM).
Would it be possible to request delivery of the latest and greatest Plusnet modem/router? Happy to pay postage.
Or would this have to wait until contract renegotiations? In which case I'll likely look to buy a VDSL router.
Re: Request to upgrade router
17-08-2017 10:34 PM
On eBay a Plusnet Hub One seems to go for under £10 including postage.
You will have to put your own settings in (the router won't automatically set up correctly) but you could get one that way.
You can generally get one "free" as part of a renewal of contract (you will still pay postage) but otherwise they have some silly price tag.
A BT home hub is also usable.
19-08-2017 3:34 PM
I think the 2704n gives more ADSL stats than the Hub One. It doesn't work with any stats monitoring programs, but the 2704n does display a fairly full set of stats on an advanced page somewhere.
19-08-2017 4:02 PM - edited 19-08-2017 4:02 PM
I've got a HubOne, only because we have a long line length to the exchange (landline went down twice - so that shows how good the connection is), the speed was poor and changed to Fibre. You have to pay a delivery charge, and may have to take out a another contract, or I guess extend the one if you're on one. PlusNet are hardly going to supply a router for £7.
If you're happy with the connection and don't mind committing then I think fine. Otherwise I don't know if there is an option to pay for the router outright with no contract?
19-08-2017 4:46 PM
19-08-2017 4:52 PM
And being locked to BT/PlusNet - there must be some strange reason they do this. Probably to stop people selling it on eBay. Though it is your property, you should be able to do with as you please, as long as you pay your contracted amount then what is the problem?
If there is any logic to it, I fail to see why.
You may as well buy a generic unlocked one.
19-08-2017 6:31 PM
Perhaps being charitable, my guess is that the lack of flexibility in settings with ISP supplied routers is more to reduce support calls.
If you get a PlusNet supplied Hub One (or any other current router as far as I know) and plug it in it "just works".
For the average punter this is ideal.
I wouldn't pay more than about £20 for a Hub One but for "free" with a fibre contract it is fine.
21-08-2017 1:02 AM
21-08-2017 6:08 AM
My best bet is that something inside or outside your home has changed.
There is a speed fault diagnosis on the Plusnet web site. Follow that exactly including plugging in to the test socket. If that doesn't fix things the best bet is a line or Openreach cabinet fault. I doubt it is a router fault.
