Replacing standard adsl router with router with gigabit ethernet ports
Swordfishtrombo
I need to replace the standard plus net router as it only has 100meg ethernet ports and i wish to use it with a nas.
Can anyone recommend an alternative router that offers this for as cheap as possible. Thanks
4 REPLIES 4
hansifan
Re: Replacing standard adsl router with router with gigabit ethernet ports
I use a Netgear model D6400
AC1600 WiFi VDSL/ADSL2+Modem Router, Simultaneous Dual Band Gigbit
4 Gigabit Ethernet ports.
Hope this helps
Mustrum
Fixes: 77
@Swordfishtrombo Many people on here use a BT Home hub 6, its relatively cheap, available on your favourite on line auction site under £30. Just aim for the normal or business one, not the FTTP one.
wisty
Fixes: 8
Cheapest solution is to get a Gigabit switch.
https://www.amazon.co.uk/Linksys-Business-Desktop-Gigabit-Unmanaged/dp/B00HZMVTBK/ref=sr_1_1_sspa?ie...
Connect one port to the router (100Mbit is faster than your broadband connection). then connect the NAS and PC to the switch.
Browni
Aspiring Hero
Fixes: 60
+1 for the switch solution.
I bought one of these a year or so ago when I needed some more free Ethernet ports.
