Replacing standard adsl router with router with gigabit ethernet ports
- My Router
- Re: Replacing standard adsl router with router wit...
06-12-2018 7:42 PM
Can anyone recommend an alternative router that offers this for as cheap as possible. Thanks
Re: Replacing standard adsl router with router with gigabit ethernet ports
06-12-2018 8:01 PM
I use a Netgear model D6400
AC1600 WiFi VDSL/ADSL2+Modem Router, Simultaneous Dual Band Gigbit
4 Gigabit Ethernet ports.
Hope this helps
06-12-2018 8:08 PM
@Swordfishtrombo Many people on here use a BT Home hub 6, its relatively cheap, available on your favourite on line auction site under £30. Just aim for the normal or business one, not the FTTP one.
06-12-2018 11:19 PM - edited 06-12-2018 11:20 PM
Cheapest solution is to get a Gigabit switch.
Connect one port to the router (100Mbit is faster than your broadband connection). then connect the NAS and PC to the switch.
06-12-2018 11:51 PM
+1 for the switch solution.
I bought one of these a year or so ago when I needed some more free Ethernet ports.
- My Router
