Replacing Hub One
eldoclear
Replacing Hub One
Hi All,
I'm replacing my currentHub One with a new Hub One.....
To make life simple I'll be changing the SSID and WPA2 to match the current one, is there anything else I need to change?
7 REPLIES 7
Fixes: 415
Re: Replacing Hub One
@eldoclear  Welcome to the forum.
If he hub is being supplied by Plusnet then no, the rest of the configuration should be automatic.
If it's one from an alternative source then you will have to manually input you user name and password.
eldoclear
Thank you very much
LaurenB
Fixes: 131
Hiya @eldoclear, as @Baldrick1 has advised everything else should automatically configure if it's one we have sent you out.
Should you need any further assistance however, please don't hesitate to get back to us.
 Lauren Barry
eldoclear
Hi LaurenB
Thank you - no problems with router automatically configuring. It was just the changing of the SSID and WPA2 to match the old one I'd worried about
Thanks Again
S
Fixes: 415
@eldoclear
Changing the SSID and password is something that I always do on a router or extender. This stops any visitor or nosy parker reading the SSID and password, which are often on display on the back, then piggy backing on to my WiFi. If you forget your new password all that you need to do is a factory reset and it will revert to those on the label.
eldoclear
Cheers Baldrick1
Although I must admit that my main driving factor was laziness, there are wi-fi enabled devices in the loft, if I hadn't changed the details to the original settings, it would've have meant climbing up step-ladders into loft, more importantly it meant trying to get back down again............
Strat
Fixes: 565
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
