Replacement power adapter for Plusnet Hub One
- My Router
- Replacement power adapter for Plusnet Hub One
13-09-2016 8:14 PM - edited 13-09-2016 8:15 PM
The lightning took out my power adapter for my plusnet hub one router.
Tried to buy a replacement at Maplin but the connector is non standard.
Has anyone else found a suitable replacement? Or do I have to buy an entirely new router?
Message 1 of 3
(5,349 Views)
2 REPLIES 2
Re: Replacement power adapter for Plusnet Hub One
13-09-2016 8:23 PM
As far as i know from other posts the hub one is a bt hub 5 type A router rebranded, if that's correct here is a power adapter for that maybe someone will confirm it for you it will work first.
https://www.amazon.co.uk/Router-replacement-power-supply-adaptor/dp/B00RM5Y35Y
Message 2 of 3
(5,343 Views)
15-09-2016 10:08 AM
Thanks - in the end, I went back to Maplin with my router and we tried a selection of connectors until we found one that went in and allowed the unit to power up. The 20W multi voltage one (set to 12V!) works great.
Message 3 of 3
(5,309 Views)
- My Router
