Replacement Router
scottish1gunner
Replacement Router
been told by plusnet to buy my own router to replace the 2nd one thats gone faulty  as they only replace it once
whats the cheap but decent on ebay     wifi isnt important   as we use a mesh system    or what works best with fttc
3 REPLIES 3
Fixes: 416
Re: Replacement Router
@scottish1gunner
If your mesh system has a built in router then you should buy a modem, not a router, or as it should be described, a combined modem/router.
Which mesh system have you got?
scottish1gunner
Hi
We have 2 newish ubiquiti ap across 3 floors
bobpullen
Fixes: 315
@scottish1gunner - in what way has it gone faulty?
