Replacement Modem
samcogan82
Replacement Modem
Looks like my OpenReach modem is on the way out, and talking to support they can only provide a new 2 in 1 hub, which I don't need. I have a full Ubiquiti setup with Unifi Access Gateway for routing, so I just need a replacement modem. Any suggestions for one that compatible with Plusnet Fibre and performs well?
4 REPLIES 4
Fixes: 1,466
Re: Replacement Modem
Moderators Note
This topic has been moved from Fibre to My Router
Fixes: 1,466
DrayTek Vigor 130 is meant to be a solid replacement.
louiswood
draytek range are the best in my eyes for the premium side of things, netgear also do one called the dm200-100eus. i also use a unifi setup and i use a Draytek modem as a passthrough and use a usg for handling the modem side of things as all login details are on there but can be used on both. Draytek just had better reviews and most people I spoke to on unifi forums suggested dreytek aswell.
DaveyH
Champion
Fixes: 12
You can still pick up the Huawei HG612 on eBay for not much money. Failing that the Draytek Vigor 130 as suggested by others is a good bet
