Replace 2704N router
iKarampa
I am getting a Linksys EA6350 router and I would like to use it for the 5Ghz and QoS features. I would like EA6350  to be my main and only router on my home network.
How can I do this?
5 REPLIES 5
Fixes: 419
Re: Replace 2704N router
Why would you want to do this? You will need a modem of some sort to put on the front end. There are much better ways of adding 5GHz capability such as getting a combined modem/router.
RichardB
Seasoned Champion
Fixes: 39
HI iKarampa,
You need to use the 2704n or another device as an ADSL modem.
The Linksys device does not contain an ADSL modem.
There are some instructions in the following post to convert the 2704n into a "modem only" device:
https://community.plus.net/t5/Broadband/Setting-the-2704n-router-to-be-a-modem/td-p/1395507
iKarampa
My area will be upgraded to fiber this year.
Can you recommend an decent modem+rooter combo?
Regards
Mav
Fixes: 515
Moderator's note:
Moved to appropriate board.
Forum Moderator and Customer
Fixes: 419
@iKarampa
You could start here https://community.plus.net/t5/My-Router/Recommended-alternatives-to-Hub-One/m-p/1505704#M5267.
If a Smart Hub interests you then look here https://community.plus.net/t5/My-Router/Smart-Hub-6-Variants-and-Performance/m-p/1504366#M5170
