Redmi AX6000 won't connect to internet
Fixes: 387
Re: Router won't connect
What's not 'up to date' on the Hub2? My Fritz!Box is technically older, and only receives 'updates' that don't make any real difference maybe every 12-15 months.
Skuzzer
https://community.plus.net/t5/user/viewprofilepage/user-id/1110
Fixed but don't ask how. I rang Plusnet about it be they said they could only help with Plusnet routers. About half an hour later I logged into my homepage at Plusnet and updated my Password. When I then logged in on the OpenWrt Xiaomi Redmi AX6000 router it worked and I was about to put it in the bin.
Thanks to you all for your help
Graham
markhawkin
Champion
Fixes: 22
For completeness, a "simple" password (not to many "special" characters) seems to be needed with some routers.
I wonder if the Plusnet password had something that the router didn't accept correctly in the password field.
