Red internet light
- My Router
- Re: Red internet light
Red internet light
12-12-2016 2:43 PM
can someone tell me how to get the red light off the router for the internet
12-12-2016 3:01 PM
1. if you are connected.... don`t worry about it..
2. try a power off, and re-boot.... unplug the router from the mains.. wait for at least 1 minute... then plug in. and see if it clears when connected.
3. if that fails.... contact PlusNet on the "live chat" line.. ( from another computer/phone/tablet whatever). ( assuming it is a plusnet router )...
12-12-2016 3:32 PM
Testing your line isn't showing any obvious issues. I've placed an order that should complete overnight to double check that your line is provisioned correctly but I would definitely advise reporting a fault to us at https://faults.plus.net
13-12-2016 4:12 PM
I have found that the reset button at the back of the router works fine to reset this. My internet keeps working but maybe without router security so needs to be corrected.
