Recycle Old Router
cthwaites
Recycle Old Router
I just upgraded my router and want to return my old Plusnet router for recycling. Any support would be much appreciated!
3 REPLIES 3
adam945
Fixes: 113
Re: Recycle Old Router
Hey @cthwaites
Thanks a lot for getting in touch, and for wanting to return your router in a sustainable manner. Details on doing so can be found here.
 Adam
 Plusnet Help Team - Leeds
Alex
Fixes: 13
As Adam said that is good of you.
Personally, if the old one still worked then it may be worth keeping it as a spare. I've had an old router die on me once, but it wasn't obvious. If it happens to your new one, then at least you can swap it back and it will get you out of trouble for a while.
KeenanSipes
I totally agree with you, keeping your old router is always a good decision. Whenever you will use your old one, keep in mind that you need to update the firmware to the latest version. You can also use your old router as a range extender too.
