Receiving incorrect Static IP address when using HH5a with Openwrt
dpritch0862
Can anyone suggest and any amendments I can try. I also have the same issue with a Linksys EA4200.
Rgds
8 REPLIES 8
RichardB
Seasoned Champion
Fixes: 39
Re: Receiving incorrect Static IP address when using HH5a with Openwrt
Hi @dpritch0862
Are you referring to a WAN static IP address?
If so, taking a guess that you are using the Static option in OpenWRT...
You should be using PPPoE to connect to Plusnet and not the static address option.
When you have a Plusnet static IP, the PN system hands out the same IP address to the router on each PPPoE authentication.
Regards
Richard
dpritch0862
I am using PPPoE to connect to PN. I receive a WAN IP address but it is not the one allocated to my account.
RichardB
Seasoned Champion
Fixes: 39
Strange. Iwould be suprised if it is an issue with OpenWRT.
I set my mum up with a static IP and a HH5a running OpenWRT and she gets the correct static IP address.
When I had a static IP my OpenWRT router picked up the correct IP address.
Do you find you receive the correct Static IP when not using an OpenWRT router?
dpritch0862
Yes I receive the correct WAN IP if I use the PN router ,a HH5a with BT firmware and a CISCO 887VA. Not sure what to do now as do not want to use the CISCO as it is quite bulky.
Mav
Fixes: 515
Moderator's note(s):
Thread moved from Fibre Broadband to My Router
Forum Moderator and Customer
bobpullen
Fixes: 316
How are you determining what the IP address is? What is the incorrect IP you're being assigned? Is it always the same?
dpritch0862
The WAN IP is always different. I have also noticed an error massage when trying to connect see capture1.png. Also I get the following message on a webpage see capture.png
Fixes: 393
@dpritch0862  that's the BT wholesale page that you see when the connection can't be made and the BT wholesale system has allocated a default IP address. This is usually due either to a routing issue or an incorrect domain in the user details. Given that you can connect sucessfully using PN Hub one, it would appear it's not a routing issue. It therefore looks like the domain part of the username is not correct. The username is youraccountname@plusdsl.net , the plusdsl.net being the domain in question.
