Re: Wifi constantly dropping out
Peter_Paul_fox
Hi, just got FTTC and Hub one router. Hub one router won't do MAC and fixed IP addresses. My old DSL n55u could do both. I can set the 55u as an access point, but can I turn off DHCP on the Hub one and leave DHCP on the access point and use LAN to LAN as normal. Also I will turn off WiFi on Hub one as the 5G signal is very weak on Hub one which has been well covered in the forum. Hopefully solve two problems. Thanks
1 REPLY 1
Fixes: 1,482
Moderators Note
This topic has been split from another thread to avoid confusion.
