Re: Wifi constantly dropping out
- My Router
- Re: Wifi constantly dropping out
02-12-2020 8:28 PM
Hi, just got FTTC and Hub one router. Hub one router won't do MAC and fixed IP addresses. My old DSL n55u could do both. I can set the 55u as an access point, but can I turn off DHCP on the Hub one and leave DHCP on the access point and use LAN to LAN as normal. Also I will turn off WiFi on Hub one as the 5G signal is very weak on Hub one which has been well covered in the forum. Hopefully solve two problems. Thanks
Message 1 of 2
(387 Views)
1 REPLY 1
03-12-2020 4:47 PM
Moderators Note
This topic has been split from another thread to avoid confusion.
Message 2 of 2
(318 Views)
- My Router
