Re: Plusnet Hub One Firmware Update Request
Fixes: 106
The version is correct though, so it's definitely accepted the update.
mort7890
Hi @bobpullen
It appears as if it has accepted the correct version I just wanted to confirm the date as that had not changed.
CT1610
Hi, don't know if you can help me i wonder if pushing a firmware update to my router will solve my issues or if its some thing else. I experience constant lag and stall when trying to load web pages on mobile and tablet devices. Happens in apps too where i have to turn off wifi and reconnect in order for the web page or app to load correctly? Looking at my router home page i see Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 10/08/17. Any advice? Ive tried online webchat for a fix but never available.
Chris.
Fixes: 106
@CT1610, I've pushed the latest update to your device but given the description of your problems I'm not overly confident it will make any difference Undecided
CT1610
Thanks for this, any ideas what could be the problem if this doesn't fix things? Ive tried all the self help articles.
Cheers
Chris
Fixes: 538
Hi Chris.
The type of problem you're experiencing could be caused by a variety of factors.
Do you the issues just manifest over WiFi or over a wired connection too?
If they're solely wireless related it may be worth trying the steps here: https://community.plus.net/t5/Plusnet-Blogs/How-to-boost-your-wi-fi/ba-p/1450193
