Re: Plusnet Hub One Firmware Update Request
- My Router
- Re: Plusnet Hub One Firmware Update Request
18-12-2018 9:43 PM
Currently have 2 Plusnet Hub One running firmware 4.7.5.1.83.8.237.2.2, iv tried the reset idea and doesn't seem to work. Could you push update if I give you both serial numbers.
James
18-12-2018 9:48 PM
Moderators Note
Posts split into its own topic for better visibility.
19-12-2018 9:18 AM
20-12-2018 3:37 PM
02-01-2019 2:38 PM
02-01-2019 10:22 PM
02-01-2019 10:25 PM
04-01-2019 11:19 AM
Hi @Gandalf
So is there an update to Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 19/07/17 or is it just the date being updated.
04-01-2019 11:42 AM
Hi @mort7890
There are newer firmware versions, but are generally only used to try to diagnose and fix an issue.
04-01-2019 1:50 PM
Hi @Gandalf
3 weeks ago
Hi @mort7890
I could be wrong but I'm still fairly certain there's a newer version.
I've posted a message to our products team to confirm what the latest firmware version is.
Will update when i hear back.
So there is a newer version, no information posted and it looks like a case of "if it's not broken don't fix it"
Didn't think accounts was broken.
04-01-2019 1:59 PM
Pretty much.
If you're not having any issues with your router why fix it?
09-01-2019 11:55 AM
@mort7890, your hub has been upgraded to the latest available firmware version.
09-01-2019 5:13 PM
Hi @bobpullen
Thanks for the upgrade, has it been available since July 2017?
Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 19/07/17
09-01-2019 6:27 PM
No, only recently.
Not sure why the timestamp hasn't updated
09-01-2019 6:43 PM
- My Router
