Re: Plusnet Hub One Firmware Update Request
Lowepepsi2004
@Gandalf
Currently have 2 Plusnet Hub One running firmware 4.7.5.1.83.8.237.2.2, iv tried the reset idea and doesn't seem to work. Could you push update if I give you both serial numbers.
James
20 REPLIES 20
Fixes: 799
Moderators Note
Posts split into its own topic for better visibility.
Fixes: 843
Hi James.
Sure thing, feel free to PM me the serial numbers.
Could I also ask what issues you're experiencing which is prompting a firmware update request?
Fixes: 843
Thanks for your private message James.
I've requested that the firmware in your routers are updated.
I'll post back once this is completed.
Fixes: 843
We've updated the firmware in your router which looks like was done on 31/12/2018.
Let me know if you have any further issues.
Lowepepsi2004
@Gandalf
Sorry only just seen your post, I have DM'd you. Only 1 seems to of updated.
Fixes: 843
No worries, I'll pick this up when I'm in the office tomorrow.
mort7890
Hi @Gandalf
So is there an update to Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 19/07/17 or is it just the date being updated.
Fixes: 843
Hi @mort7890
There are newer firmware versions, but are generally only used to try to diagnose and fix an issue.
mort7890
Hi @mort7890
I could be wrong but I'm still fairly certain there's a newer version.
I've posted a message to our products team to confirm what the latest firmware version is.
Will update when i hear back.
So there is a newer version, no information posted and it looks like a case of "if it's not broken don't fix it"
Didn't think accounts was broken.
Fixes: 843
Pretty much.
If you're not having any issues with your router why fix it? Smiley
Fixes: 127
@mort7890, your hub has been upgraded to the latest available firmware version.
mort7890
Hi @bobpullen
Thanks for the upgrade, has it been available since July 2017?
Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 19/07/17
Fixes: 127
No, only recently.
Not sure why the timestamp hasn't updated Huh
mort7890
Hi @bobpullen
That's why I queried it as it still shows the same date.
