Re: Hub One and port forwarding
mg
I have just had my second Hub One - both are unable to open 8068, but did open 80 - so not operator error! Plusnet have washed their hands, as 'Port Forwarding is unsupported'. From the Gurus out there, can you recommend a router that I can buy that is not too expensive - I am familiar with Netgear products, but not opposed to other suggestions
5 REPLIES 5
Mav
Fixes: 515
Moderator's note by Mike (Mav)
Message moved and title changed for better visibility.
Forum Moderator and Customer
SpendLessTime
Fixes: 86
@mg
Just to say this thread for the BT HH5 (which is the same as the Hub One internally) shows how to open port 8068 for a Heatmiser Wireless Thermometer at message 5? Is it of any use?
mg
@SpendLessTime
Many thanks for your suggestions, which I have followed, however the problem remains - 80 is open but 8068 refuses to open (and also 8080) - from reading other posts, it appears that there is a port forwarding with both HomeHub 5 and by default with the Hub 1. It is unacceptable that PlusNet provide a router that is not fit for purpose.
SpendLessTime
Fixes: 86
Well it was worth a try to see if those instructions worked. Sad
I had hope that disabling UPnP might have been the trick.
Fixes: 160
What's the firewall settings here? https://portal.plus.net/my.html?action=firewall
