Random Factory Reset Plusnet Hub One
- My Router
- Re: Random Factory Reset Plusnet Hub One
22-11-2016 12:59 PM
Hi all,
woke up this morning to find my Plusnet Hub One had totally factory resetted itself and the orange light on the front was flashing.
It required a reboot and upon rebooting all my settings were gone, although I could tell they were reset before the reboot since my AP had the default name.
Very annoying as I had quite a few ports forwarded and things tweaked...anyone able to shed any light on why this may have happened?
Hoping to avoid this again, but to be honest, I may just buy a different router.
Thanks for your help.
Rory.
22-11-2016 1:10 PM
I had exactly the same issue last night.
Details:
Plusnet Hub One
Software: 4.7.5.1.83.8.226
I now have all kinds of issues with setting up advanced settings (changing SSIS and IP address both don't work).
I will raise a seperate forum issue for these.
I hope others might confirm they had the same issue as you.
22-11-2016 1:16 PM
Ah, interesting to hear if anyone else had the same issue. Thanks for letting me know.
22-11-2016 1:47 PM - edited 22-11-2016 1:53 PM
Similar behaviour here but no factory reset fortunately.
Event log at time of disconnect:-
00:42:28, 22 Nov. (238517.960000) PPPoE is up - Down Rate=79903Kbps, Up Rate=19999Kbps; SNR Margin Down=11.8dB, Up=16.5dB 00:42:28, 22 Nov. (238517.940000) CHAP authentication successful 00:42:28, 22 Nov. (238517.710000) CHAP Receive Challenge 00:42:28, 22 Nov. (238517.710000) Starting CHAP authentication with peer 00:42:28, 22 Nov. (238517.710000) PPP LCP Receive Configuration ACK 00:42:28, 22 Nov. (238517.700000) PPP LCP Send Configuration ACK 00:42:28, 22 Nov. (238517.700000) PPP LCP Send Configuration Request 00:42:28, 22 Nov. (238517.700000) PPP LCP Receive Configuration Request 00:42:28, 22 Nov. (238517.440000) CHAP Receive Challenge 00:42:28, 22 Nov. (238517.440000) Starting CHAP authentication with peer 00:42:28, 22 Nov. (238517.430000) PPP LCP Receive Configuration ACK 00:42:28, 22 Nov. (238517.430000) PPP LCP Send Configuration Request 00:42:28, 22 Nov. (238517.430000) PPP LCP Receive Configuration Reject 00:42:28, 22 Nov. (238517.430000) PPP LCP Send Configuration ACK 00:42:28, 22 Nov. (238517.430000) PPP LCP Receive Configuration Request 00:42:28, 22 Nov. (238517.420000) PPP LCP Send Configuration Request 00:42:23, 22 Nov. (238512.820000) Admin login successful by 192.168.1.63 on HTTP 00:42:04, 22 Nov. (238493.890000) New GUI session from IP 192.168.1.63 00:37:10, 22 Nov. (238200.080000) CWMP: session closed due to error: Could not resolve host 00:37:10, 22 Nov. (238200.070000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username 00:37:10, 22 Nov. (238200.060000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' 00:36:40, 22 Nov. (238169.790000) CWMP: session closed due to error: Could not resolve host 00:36:40, 22 Nov. (238169.770000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username 00:36:40, 22 Nov. (238169.760000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' 00:36:40, 22 Nov. (238169.500000) CWMP: Initializing transaction for event code 4 VALUE CHANGE 00:36:39, 22 Nov. (238168.790000) PPPoE is down after 804 minutes uptime [Disconnected] 00:36:36, 22 Nov. (238166.030000) PPP LCP Send Termination Request [Peer not responding]
you can see my login and reconnect at 00:42
eta BQM at time of outage
22-11-2016 2:36 PM
My Hub One disconnected at about 2.10am. I couldn't get it to stop power cycling long enough to get into the Admin screen. I rang up and they suggested reinstating my old Router/Modem which worked. As I was on the phone they received a message saying many people were having this trouble.
22-11-2016 3:39 PM
Guys - word on the street is that this could be an issue with the Plusnet hub and the Google Chromecast audio dongle:
https://productforums.google.com/forum/#!topic/chromecast/3PiH_40qLBw
I'm going to try unplugging mine tonight and seeing if it stabilises things...
22-11-2016 4:49 PM
Interesting..I shall try this tonight when I get home.
Also incredibly frustrating.
22-11-2016 6:13 PM
OK, guys. I have switched my chromecast audio off and the router is stable. Looks like that is the problem. Thank you to all that have helped.
- My Router
