RSSI for 2.4Ghz and 5Ghz signals awful
- My Router
- RSSI for 2.4Ghz and 5Ghz signals awful
25-03-2020 2:55 PM
I suspect like many I've suddenly started utilising my wifi more than previously. Even though i sit approx. 10ft from my route my wireless signal is sometimes so bad i drop from Skype calls.
Initially i thought it may just be the 5Ghz signal issue, but i now utilise the 2.4Ghz signal and i still face issues.
I downloaded a program called wirelessnetview which identifies signal strength for all wireless networks in range. Currently the RSSI for my 2.4Ghz signal is -60, for the 5Ghz its -71. My neighbors Virgin signal has lower numbers and it's at least two double brick walls away.
Re: RSSI for 2.4Ghz and 5Ghz signals awful
25-03-2020 3:26 PM
Ensure you don't have cordless phones & the like in vicinity of router. Openreach have also advised today that using a microwave is detrimental to wifi speeds too.
26-03-2020 4:45 PM
I swapped from channel 1 to channel 6 as this was the least congested one, this has bought some improvement.
The RSSI for the 2.4GHz still likes to spike on occasion though which results in a massive degradation in signal.
My router is not located near cordless phone or microwave.
- My Router
