RJ11 Cable To Cut Down Interference
- My Router
- RJ11 Cable To Cut Down Interference
29-11-2016 8:59 AM - edited 29-11-2016 9:06 AM
Have one of these https://www.amazon.co.uk/gp/product/B008IKVA1W/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 at the moment between my router and OR MK III master socket. I think I might be getting interference from the central heating causing drops and freezing on streaming. Just wondered if there was a better cable I might be able to use?
Re: RJ11 Cable To Cut Down Interference
29-11-2016 9:38 AM
These have a good reputation.
Do you actually need it to be 5 metres? Shorter is better.
ADSL2+ Billion 8800NL
29-11-2016 11:16 AM
As I have said before I use two of these both 10m long with most of the wire bundled under my cabinet and I don't suffer from any form of degradation. However, with these being unavailable on Amazon I'm sure you'll get the shorter variant elsewhere online.
29-11-2016 8:27 PM
05-12-2016 9:46 PM
I use one of these with an OR MK2 Socket and get :
Link Rate | 79999 Kbps | 19999 Kbps |
If thats any help
- My Router
